Bugs Bunny switch problem
arakisssun
Varna, Varna, Bulgaria
I have problem with the registering when the ball is on the hole at up left kicker(where is loacted coil A-14210).The coil working,but when the ball is in the hole-nothing happens.
Before stop working,it worked strange-sometime reisgter it without problem,but sometimes it registered only when I begin to push the left or righ flippers one after other.After several tryes,stop working
I cheked the microswith and the diod-both works
What can it be,any idea?
I'm trying to find the switch in the manula but is missing I think
I dont know the pin but have you physically used a ball to check the microswitch? Sometimes the wire guide needs slight adjustment by bending it
Have you tested the switches in the "switch test menu". If not, then do so. A good switch won't work if there is a broken/loose wire leading to it somewhere. If I understand your issue, then the coil is not being triggered properly. Look at the switch test results, and I suspect you will find your problem.
Let us know what you come up with. A quick hint, on the display, at the end of the score or where it says "Free Play" if there is a dot after it, then the game knows there is a switch out. Also, when you first turn the game on, if the display flashs "Press Test for Report". That message is also telling you that there is a switch not registering.
Tom
Results
When I sart auto switch test cycling :
06 11
06 14
06 40
But when I star manuaa switch test this switches 11/14/40 are working(registering),but the switch that is the main problem is not registering
So what next?
I see something other too.
The game can star to play even one ball to be missing.Even the machine is turned off/on ,it's not searching for missing ball
