Bubbles - Willams Sideart
DarthSonic
Massachusetts
I have a Bubbles cab that was painted over black and converted to a smash t.v. I already removed a smash t.v. decal from one side and started to remove some of the black paint (using a heat gun and a paint scraper). I've only done a small spot, however, some of the bubbles art is coming off with it.
Are the bubbles on the side art decals, stenciled, or a mixture of the two? The black paint is strong and doesn't bubble when I use a heat gun. Before I try Citrustrip, I figured I'd check here to see if anyone had recommendations and if anyone knew for sure if the bubbles were decals or not.
By the way, I can see the outline of each bubble and the outline of the bubbles' mouths through the black paint if that helps.
Thanks in advance!
