Bromley ghost town
ekeeb
Scurry, Texas
Need a manuel,or a wiring diagram.powers on the leds are all 8's.wont coin up no manuels on bromleys web page either .Thanks Ed
Ok theres iso that goes into the board,the output is 15v.This cant be the correct voltage?can it.Anybody have one of these they can check with a multi meter.also have a red/with black line wire on main board coming out of harness at switcher is it 5v 12v or try 5v first then 12v after i try to figure out the iso.
ok I measured the resistance of the iso,the iso is bad,Ill try tomarrow by installing a brand used one.Heres some pics.
This is the one I was outbid on at superauctions,The wife was po i didnt get it.Payed less than what i would have at the auction.Just need someone to measure the voltage on the iso so i know what the stepdown voltage is supose to be and can replace with the correct one.
Board has 10v running therw the ground side,they cut the ground that goes to the switcher off the board.Getting closer.
Still need a manuel or scamatics
Still need a manuel or scamatics,dip switch settings?Thanks Ed
Gottem
Wow just receaved the manuel and scamatics.Thanks if you need a copy pm me with email address,paying it forward.
