Brightness problems with a frogger monitor. HELP!
morbidboy
Minneapolis, Minnesota
Problems with the frogger monitor.
1) The main problem is that every so often the screen lightens, to the point that you can barely see the screen image. The knob to darken the image is a little wobbly and its a battle to keep the brightness leveled. 9 times out of 10 after trying to adjust the brightness, it slowly gets brighter again and then I'm back twisting the wobbly knob, hoping that this will be the last try before the brightness stays the same.
2) Whats the name of the knob/part? Can it be resoldered/retighten or do I just need a new one? If so where can I get one?
3) I need to know what monitor this is so I can recap it.
that is your focus block.
they do wear out over time depending on their location and how often they were adjusted.
they are not made any more.
but your chassis appears to be a G07 so there is good news.
there are tons of theses parts chassis out there to get another one.
Peace
Buffett
