mbott1701 Active member Donor 2024 VAPS Joined Jul 12, 2007 Messages 927 Reaction score 53 Location Allentown, Pennsylvania Jul 31, 2010 #1 I'm having trouble finding a direct replacement for a BR-81D (2A 100V) bridge. Can I use a 2A 600V bridge as a replacement instead?
andykmv Active member VAPS Joined Jun 27, 2009 Messages 1,535 Reaction score 23 Location Kilmore, Vic, Australia Jul 31, 2010 #2 mbott1701 said: I'm having trouble finding a direct replacement for a BR-81D (2A 100V) bridge. Can I use a 2A 600V bridge as a replacement instead? Click to expand... you can, but digikey have this replacement for the br81d instock: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=2KBP01M-E4/51GI-ND for 88c check the packaging outlines, pin spacings and pin diameters before you buy the 600v version though just in case the legs are bigger - may have a problem fitting it through the holes if that is the case! (i havent checked the mechanical specs)
OP OP mbott1701 Active member Donor 2024 VAPS Joined Jul 12, 2007 Messages 927 Reaction score 53 Location Allentown, Pennsylvania Jul 31, 2010 #3 Thanks for the link. I actually just found the same one on Mouser's site too.
Riptor Well-known member VAPS Joined Jul 10, 2007 Messages 12,078 Reaction score 144 Location Leonartown, Maryland Jul 31, 2010 #4 KBL08 might work. When it comes to a BR bigger is better if you can make it fit. http://store.pacmandotcom.com/38-bridge-rectifiers
