Braze Technologies closed Mar 4th thru 13th
braze
Braze Technologies will be closed March 4th through March 13th.
I will not have internet access. Orders will resume shipping on
the 14th depending on stock. As normal all my released kits are
usually in stock at www.mikesarcade.com and www.arcadeshop.com
Thanks. -Scott
Why does Mike sell the Space Invaders for 25.00 more than Arcadeshop?
Also it says that the game should work before installing this kit, well my SI just stopped working and I was kind of hoping this kit would either fix the problem or help diagnose it, any reason the game HAS TO work?
no it doesn't have to, but unless the game has just a bad rom (or bad rom socket), its not going to work. Now it does add a ram test (similar to the early atari games (low and high beeps). So if you have a bad ram, it could help you diagnose which chip is bad.
For one, you won't know if your kit install is good if the game doesn't work before hand. Seeing the same dead results after the install does indicate that the kit and the install (good or bad) didn't fix it. ;)
I've personally used the SI kit as a troubleshooting tool many times... the fact that it has extra games is a bonus :) . The RAM is bad on those so often, and other testing methods are tedious... with the "beep test", it usually makes quick work of fixing those boards.
DogP
All orders shipped
All paid orders have shipped. I will be closed thru the 13th.
orders will resume shipping then. -Scott
