Does the Braze SI multi kit work on Taito 3 stack color pcb's? I know there are confirmed cases of the kit working on b&w Taito SI pcb's, but I can't get it to work on my color 3 stack pcb.
It does, it wont do color prom switching. The core of all these games are the same from the CPU perspective. Color was just an add on circuit, the game knows nothing about it nor can control it.
I may have an issue with the Taito rom then. If I put the Midway rom in, the kit works on a Midway set (at least the test function, my Midway board has an issue) .
If I put it in the Taito board shown above, I just get the lines that show up if no roms are present.
Is the Taito rom file available so I can burn another one and try again?
The Taito pcb works perfect without the kit.
it is supported on midway SI and midway SI deluxe. Those are all L-shaped boards with the std midway motherboard. taito boards can be L-shaped, 3 board stackup, color, more pcb variations, dual sound cards, more game variations, etc. But, is known to work on some
