GunSmoke Guy
Brand New Power Supply Happ not lighting up using it for a Burger Time conversion kit
OK so I have a Burger Time I'm trying to resurrect from the dead. For those unfamiliar they use a "Suit Case" Style power supply, I just recently bought a conversion switching kit from arcade shop and I noticed these things:
First of all after tapping into the power wires where the monitor would draw its power as said in the directions to do so. I don't see any light on the HAPP power supply (which is what i'm trying to figure out). Usually they are green / red to show you that it's on / working.
Even though that light doesn't glow on the new happ power supply, So far I see that my marquee light doesn't fully glow i'm thinking that's just an FS-2 starter most likely.
I also noticed that the service outlet on the original power brick / suit case style power supply works if I plug something in.
Currently NO pcb / logic board is currently hooked up, before I do so I want to see that little glow coming from the happ power supply.
My original power cord the ground pin broke off and is not being utilized, does the happ power supply require the ground pin going into the outlet ? Did I not tap into the right location? Also currently no monitor is hooked up.
