Every time I shoot the ball into the Mystery hole, it doesn't come out. Then the machine starts its 'Pinball Missing' search with no luck. Any of you Dracula owners ever had this same issue?
If it doesn't pop out during ball search, then something's causing the kickout coil not to fire. Take a look at it...any loose wires? Sometimes they'll pop off. If the wiring's good...check the manual for an associated fuse. If that tests OK, you might have a bad associated transistor or diode.
It does light up the Mystery award when you shoot the hole, but it's supposed to pop the ball out to the left wire ramp. Thanks for the tip...I'll check that stuff out as well.
