Bram Stoker's Dracula help
PacAttack13
Omaha, Nebraska
Turned Bram Stoker's Dracula on earlier today and for some reason the sling shots and the pop bumpers are not working during game play. Test the solenoid test and the sling shots and pop bumpers work just fine. Any ideas? Thanks.
I will test the switch edge test when I get home from work....anything else to look for? Everything was working fine and the only thing I did today was replace a couple bulbs with the power OFF. So maybe I bumped something or their is a loose wire?
If it works in test and not during a game, the switch row could be out. Run a switch test on it, if none of these register, then you need to check the wiring back to the backbox. If the wiring checks out fine, then U20 on the cpu is probably your culprit.
ok it turned out to be the U20.....replaced it and now the pop bumpers and the slings are working fine......when the U20 went out it also made my lights in my pop bumpers not work.....figured they needed new lights....put some in today and they are still NOT working......what to look for? New sockets for the lights in the bumpers? Wire connection? ???? Bad fuse? Currently at work and do not have access to a manual.....which fuse am I looking for that controls the bumpers and what type fuse? Thanks.
