BOZO's Buckets
mikdawg
Lowell, Indiana
I have a friend who has one and it is reading left coin door error. He replaced the circuit board but that did not help. Anyone have any thought on what could be the problem? I am going to look at it in two days, trying to diagnosis the issue before I get there. Thanks for the help!
Ive never worked on this game, or any redemption game. I figure the coin door is the same though. Does he have it wired up correctly to the trigger? Is the coin trigger stuck down? If you unplug the left coin doors wire, does the error go away?
Those are my ideas.
Well, I went to see it and the coin door was fine. Bucket two was not reading the ball, that was the error. After inspection, one of the boards in bucket two had a bad solder joint. Fixed it and it was up and going. Got home and he called me and said the coil that releases the balls in not working, GREAT!
