Bow before the mighty power of Novus!
demogo
Donor 14 years: 2012-2025
Texas
Holy crap!
I say again, holy crap!
So I've had this Star Trek SOS game for probably 2.5 years now and it's never been reliable. Monitor would act up (a lot), other intermittent but annoying issues. The game has spent 5x more time 'down' than playable.
So I finally worked up my courage and fixed multiple issues with the monitor (first real monitor repair beyond cap kits, all detailed in a different thread), discovered that many of my other intermittent errors were coming from flaky connectors on the card cage and worked past that, and the last remaining issue was the fracking scratches on the game's plexi.
There were a few that I could feel with my fingers but dozens of them were mostly clumped into the center of the screen. And they were ANNOYING. Much of the game's action is in the center of the screen and you had to look through all of those fracking scratches.
I'd tried attacking the problem with Novus not long after I got the game but it didn't seem to help much.
I finally reached the point of no return. The scratches were so annoying that if I couldn't get rid of them I was going to have new plexi cut and have to give up the original Sega holographic seal of authenticity on the original plexi and I didn't want to do that.
Tonight I decided to go for it since everything else was now working. I guessed that the bulk of the scratches were on the outside of the plexi and I WENT AT IT. I lightly cleaned the plexi with Novus 1 first, then ATTACKED the scratches with Novus 3 for probably 20-30 minutes, pressing HARD. Then Novus 2, polished it off, saw that about half the scratches were gone and much of the rest reduced, went back to 3 and attacked the remaining scratches, 2, and so on.
I was finally left with just the scratches that I could easily feel with my fingernails and figured I had nothing to lose so I went after those the same way and eventually reduced those down to little blips and then to nothing.
It was about 90 minutes of hard work but the final result is BEAUTIFUL. There are still some typical circular very fine scratches that you'll see in any plexi but ALL of the annoying scratches that bugged me are GONE, even the deeper ones.
Wow, Novus, I love you!
Pics Demo, wtf?! Grats on a job well done. :)
I just did this to my headlights on my truck. The plastic covers were all milky to the point you could barely see the light bulb inside. Took Novus to it on a cloth bonnet on a random orbital buffer...wow! Like new!
Well, I didn't take any specific 'before pics' so I thought I wouldn't have anything to show.
But it turns out it was so bad that some of it is clearly visible in these:
attachment.php
attachment.php
attachment.php
And now the 'after':
First pic is slightly blurry and the 2nd pic is horribly overexposed due to the flash being on that time but it does clearly show the plexi and the lack of horrible scratches in the middle.
attachment.php
attachment.php
Thanks. The 'after' pictures don't really do it justice. The scratches are just *gone*.
There's a bit of weird streakiness in the pictures and whatever flaws that are visible beyond the streakiness are mostly 'stains' of some sort on the plastic covering on the monitor.
