bolts
Djm
anyone have a trick on how to get tiny 8mm nut off of a bolt that just keeps spinning with it and now way to stop the bolt since its rounded no slots for screwdriver and nothing to grab not with a crescent wrench or anything
How about some pictures of both sides? I have some ideas.
Like a carriage bolt?
One time for a stubborn carriage bolt that was doing the same thing to me, I took a dremel with a cutting disk and cut a slot into the top. You can then use a flathead screwdriver on it while using a wrench on the back. I also sprayed the nut down with PBBlaster and let it soak a bit. Came right off after that.
If it is just one, and I can get an air gap, I pry it apart for some tension. A little bolt can be cut or sawn if it is not in plastic or you care about the finish.
Or get a similar sized bolt.
Apply super glue to the head (assumes flat head on existing bolt) and stick it to the existing bolt head.
Allow the super glue to go through a full cure (24 to 72 hours, read the instructions.)
Now you can grip the bolt in vice grips (being careful NOT to apply a side load or it will snap off) and undo the nut.
You can try to file the head down if it isn't flat.
If you have a welder, you can also weld the bolt to another bolt, but this is pretty small so that would be really hard.
Lots of ideas here. I haven't seen "use a nut splitter" yet.
So…
Use a nut splitter. You should be able to find one that's small enough.
Thanks all reading through all these today to see which to do
Vise grip on top and then back off the nut. Oscillating tool between the washer and nut.
