Bob roberts WMS battery conversion...help.
obs
Calgary, ab, Canada
Hi all..
The install is straight forward......but.....
In the kit, I got the battery holder, battery and a resistor.
On bobs site, there is no mention where to put the resister. Does this go in place where the 2 inch black 18 gauge wire goes???
Tnx.
There "should" be a diode in the circuit already to keep the alkaline batteries from being charged. Having a 2nd one should not cause a problem as long as it's installed the correct direction.
Yes- I think it's just a zero ohm resistor. A single black stripe?
Yes
I have never got a resistor with this kit?
Yes, you have
The ones I have ordered over the last 1-2 years from Bob have come with a zero ohm resistor.
Yes, they do
Nope, no diode with the kit.
