Bob Roberts Leg Leveler Kit..
obs
Calgary, ab, Canada
Just finished installing 2 of bobs leg leveling kits on my Robotron and Joust. When I tipped the game over to get access to the bottom, I could not believe how rough shape the existing legs were in. I removed all supports, did some minor repairs to the bottom wood...some area's were split from moving the game constantly over the many years....sealed with wood glue. Does not look bad at all.
I mounted a 4 x 4 x 1/2 thick wood, glued and stapled. I let it dry for 24 hours, I mounted the plate using 1.5 inch long lug nuts. I stood the game up...rock solid.
Def would recommend. I think I am gonna do this for all my 20 games...some need it more than others.
Cheers..
Dave
I install new feet on every game I buy.. Trick is to remove the old feet when the game is sitting in your truck (on its back or side). Its the first thing I do before pulling it out of my vehicle.
Yeah, I've done a few Bob leg leveler kits. They are top notch, but I wish they weren't so expensive.
little too beefy for the standard games there. note it says megalo...thats the big ass projection tv cab.
taking a second look at those levelers...there is NO WAY I would add two holes to the side of my cabinet. If the game should ever be moved the wrong way..the wood would split and break.......
New leg levelers are a must on every vid and pin. I keep a box of them handy. I even take new ones and clear coat them if I'm puuting the machine in my arecade so as to limit the chance of them rusting onto the carpet.
