Bob Roberts Galaga Switcher Harness help
Torin
Donor 2013
Boise, Idaho
I just got a Bob Roberts Galaga Switcher Harness. It comes with two different harnesses to connect. One harness is self explanatory enough. It is the big harness that plugs into the large connector on the original Galaga harness. That, I get.
Now fogive me if this should just be obvious but I'm just not getting the second harness. The AC harness. It is just two wires with splice adapters to splice into the cabinet AC. Fist of all, I have AC hooked up to the switcher already from the ISO. Do I even need to use this? I think I am supposed to hook it into my switcher AC and then splice into the cabinet AC but it says something about a dead end "tunnel". Can anyone tell me what to do with this? I don't get the deadend splice part or if I even need to use it. Right now the game works but there are no speakers, controls, marquee etc...
Thanks for the help.
Torin
The switcher just needs 120 volt ac to run. If you're running it from the ISO, what are you running your monitor from? If your monitor and the power supply are both up and running, you're done.
Monitor is being run from the switcher down from the block on the bottom of the cab. It's powered and so is the board. I just don't have any sound or marquee light but they both could be out. My CP is taken apart and so I can't test that yet. I guess I will consider the kit installed correctly. Unless otherwise noted here. Thanks.
Torin
