CrazyKongFan
OK, I'm about ready to throw this G07 out the window
Anyway, had the chassis rebuilt, got it back, broken in the mail, sent it back, got it back, wouldn't stop scrolling, sent it back, guess a couple transisters got damaged, got it back, worked good for a couple days. Then it started coming up really fuzzy. Playing with the focus knob didn't do anything (well, it made it even worse if I went the other way). Eventually it would focus on its own after maybe 20 minutes, although the screen would still flicker once in awhile. A couple days ago, I took the chassis out to see if anything was loose (connectors, etc), and was careful. When I put it back in, it now looks like it's out of convergence (I think that's the right description). Here's a screenshot of the first level of DK (on a 48-in-1). You can see the 3 colors of each beam are separated. Is this a tube issue or a chassis issue? What do I need to look for? (note, the picture is focused...the Gaplus burn-in from the monitor is clear) If I take the chassis to another G07 tube, would it be possible to mess that tube? (I might take it to a friend who has some games, and see if it looks the same on his)
