Blue Elf2 in a Capcom Cab?
Cowboymiller
Idaho
Howdy all...noob here. i wanted to get peoples thoughts on my situation. i have a Capcom dedicated cab Street Fighter CE.
I've upgraded the cab to a 20" LCD Flat screen using this CGA/EGA/YUV to VGA adapter.....
http://www.jammaboards.com/store/cga.../prod_291.html
...Now im looking at installing the Blue Elf 2 and wanted to get some thoughts. I believe the cab is fully wired with a JAMMA setup using 2 joys, 12 buttons, 2 players...That said;
Will the BE2 simply take the place of the main SFCE board?? Thanks for the reply's in advance...
The BE2 will take the place of your Jamma board, but you'll have to modify the harness to make it work. If I recall correctly, the grounds will need to be changed or you won't get any feedback from the joystick or buttons. Also, you'll have to add the kick harness wires to the adapter.
Check out this thread as it has most of the information: http://forums.arcade-museum.com/showthread.php?t=124888&highlight=blue+elf+adaptor
