Blue elf 108in1
Koumphon
St-Hubert, Quebec, Canada
Hi all , I just got the blue Elf 108in1
Connect to the jamma , loads up , I can put credits , but cannot select games , cant move the joystick or even press start , so controls wont respond , tried on different cabinet same thing
its not a Neo-Geo Cab tho .. is it an issue ?
any suggestions ?
IF!!! I read coreectly. Later neo boards had control wiring different than jamma. Someone can elaborate on it.
Kevin
message from Nixs
that has to do with sound wiring not controls, check the control grounds and make sure they are completing a circuit
" checked to make sure you don't have ground hooked up to the 6th button on both sides that is used for the 6th button switch
it will lock out the controls if ground is hooked up
look in the manual at the pinout also
i think on most harnesses the ground is hooked up on it "
will try
