srarcade80
I have 3 blitz2k gold boards here, all 3 with same exact dip settings. One works perfect, set to 15khz. Two others are having identical problems. Game starts up, graphics are a bit scrambled but you can see whats going on, sort of like if it was running in the wrong resolution but far less scrambled. Some screens show up fine though, like the intro movie. Soon as you return to the title screen, it gets scramble again. Running this on a tri-mode monitor so it should be fine for either mode. I also tried this on a 15khz monitor too, same result. If you start a game, the tri-mode monitor starts to really freak out, you can hear the relay kicking off like crazy and at that point i have to shut it off.
I noticed on U8 under SW4 and SW5 is for setting 'graphics speed' to either 51mhz or 49mhz. This isn't well documented. I'm going to assume this is for video card performance- any ideas here?
