thefader
I put painters tape on my newly painted DK cab, then tried painting the sides black.. its bled through in two spots.. Help.. What do I do??
I use regular masking tape, just don't leave it on for days. The trick is you must push and smooth the tape edge down, using pressure from a putty knief or flat bladed tool in order to stop bleeding.
Same concept when masking and taping a room to paint...
With either kind of tape, you can see air bubbles under the tape before you push it down with a blade. Watch them disappear as you push down and you know you wont have bleeding.
