Is there a easier way to repair the black rings than the old fashioned black paint and a brush. I plan to clear coat the playfield so a decal wouldn't be the end of the world but looking for ideas.
I used a fine point paint marker from a craft store, and a plastic circle template. You can't use naptha afterwards though, because it will ruin that kind of paint.
I used a fine point sharpie for thin detail black lines.
I use sharpie the most but I wouldn't use it if you're planning to use automotive clear. Even with something like varathane I would use a couple of really light coats first. I've seen what can happen when the sharpie ink runs and it can basically ruin a playfield.
yep, I used a fine tip sharpie in a few spots, and had to resand the surface because it ran everywhere when the clear hit it. Use a circle stencil and a paint marker
