I'm about to start on the basement. Going to with BL and BL carpet plus some other things I'm sure. I have not done a lot of poking around so I am not sure of my options. Are there Black Light BLACK and Black Light WHITE versions of the 48" tubes? If so, thoughts either way? What can I expect coverage wise? The long run is about 25' long by 8' or so wide. Due to the ceiling the width varies wall to ceiling hump for the ducting above the drywall. I'm planning on doing the entire floor so I am thinking I am going to have to go a bit overboard on the lighting to get the carpet closer to the opposing wall to react.
I also have a square side room I am going to light as well.
Good places to buy bulbs in bulk?
Fixtures? From the hip I was thinking standard direct wire fixtures that I may or may not paint to knock the shine off of the typical white finish..that is unless I can find them gray or black for a good price to offset the time.
