black light bulbs
cleverlyj
Northglenn, Colorado
are there differences? i ask cause i think i've heard of the 'white' black light, but more importantly, the bulb in my satan's hollow doesn't seem to be as bright as the bulb in other trons, etc, that i've seen. anything i can do to brighten it up?
pretty sure the blacklight bulb in SH is a standard the difference in tron is the top blacklight is standard but the lower is a white blacklight
No, they do not require a different fixture.
The "purple" or "blue" blacklights are referred to as BLB.
The "white" blacklights are referred to as BL.
So, a F15T8-BLB will be a "purple" blacklight and a 15T8-BL will be a "white blacklight.
I have a local lightbulbs-only store that carries them in stock. otherwise, you can order them online. i believe Bulbman has them...
For what it's worth, I ended up going with two BLB (dark blacklight) bulbs in my Tron, as the florescence with 'em installed was noticeably better.
