dieseldogpi
Hey everyone, I picked up a Black knight recently, and after cleaning up some battery corrosion and doing a general shop job, I have a solidly working game. A couple of items still are a little off still.
-First, I have no backbox GI. The playfield GI us there, a little low, but it's on. Is there a second circuit for the backbox? I couldn't find anything in the manual.
-Not sure what the correct incline is for the playfield, mine is at about 4 degrees. I question this for two reasons: first, I replaced the springs on the shooter, and now the ball won't make it up into play. I put back in the original shooter rod spring, but kept the new barrel spring for the outside of the shooter, the ball makes it now, but it is weak. Were there special barrel springs? My playfield too steep? Also with the incline, in the upper playfield, when I shoot the ball with the upper left flipper, it circles around into the multiball lock area, it usually jumps right out, as if it is going too fast. Is this normal, is it a shot that needs to be a little lighter?
Thanks for any help you can give me guys.
