i just got a black knight, and it popped the f2 solenoid fuse last night.
i've had it for a day or two, and before it worked fine. i just wanted to double check that there weren't any other issues causing it. i think it's somewhat normal. basically what happened is that when i moved it into my basement the trough kicker solenoid was dirty and stuck and smoked. i shut it off, cleaned the coil and it worked fine sunday. i only played a game or two. then sunday night i was going through the audits and checks to reset the settings to factory and i played a quick game after that, and shut if off. turned it on a minute later and it wouldn't kick the ball out. all solenoids were dead except for the flippers and the solenoid fuse was blown. i haven't replaced it yet but i'm assuming it was probably cause the solenoid stuck and fried for the kicker that caused it. assuming it works after i put the fuse back in and it doesn't blow, is there anything else i should check out?
jim
jim
