Black Hole coil?
That's the upkicker coil. It's an A-4893
I'll check and see if others can be used in its place.
By the way, why do you need one? If yours burnt up, you better repair the cause before replacing the coil. OR, place a fuse in line before the coil. That's what I did when I was working on mine. It saved a lot of coils and is 1/10 the cost.
Thanks for the help, my coil fried but it was unlabelled. I'll be checking the associated transister and adding a fuse as I believe this coil doesn't have one in line.
What fuse did you use for this coil? Is there another # for this coil?
Marvin 3m's site is an amazing source esp for system 80.
And don't forget blackhole rules! I love my bh and most all system 80 games!
If you need a cpu I have a spare system 80 cpu coming.
Or if you need a driver boards to use as a core for rebuild, that also.
