So....where is the best/cheapest place to pick up some black laminate for a multicade cabinet?
This is the cheapest and good quality stuff that I use. I did all 4 of my arcades with this stuff. I would recommend on buying the spray adhesive from there also. The cheap spray adhesive you buy in local store don't hold that well. I already ordered with them 3 times with no problem.
I also bought the rubber foot bumpers and installed them on the back on my arcades to help protect the paint on my walls since my arcades have casters on the bottom.
http://www.reliablehardware.com/laminates.aspx
I use 2 cans per arcade for both sides and front. Spray and wait until tacky before install. Then router the edges.Just curious, how many spray cans does it take ? Also I assume you spray on both sides and wait for it to get tacky like normal laminate ?
What's the shipping from Reliable Hardware like? Is their black a match to the matte black Formica/Wilsonart that you'd buy elsewhere? Thanks
I always get mine in 7-10 days after ordering. I don't know if the black matte matches the other brands. Unless you can tell by the pics I posted earlier.
Sorry, I meant the shipping cost, how do they do that? Due to size, I figure it can be high and may need to buy in quantity instead of one piece at a time.
Thanks for the links and info!
I do not own a router and I'd rather not purchase one if i can hep it. Any other recommendations on cutting it?
Nope, router and a flush trim bit is required. Also, contact cement and a j-roller.
