BK466 cr19 to cr23 conversion
rutgersray
Brick, New Jersey
I have taken the universal adapter wiring chart from BK and used a cr19 which was already attached to my 466 to make a home made cr23 using an old 23 from another tv neck board. According to the cr23 wiring chart, their ore only 9 wires on the adapter. using holes 1 and 5 through 11. Still left on the cr19 after conversion are wires for red G1 and G2 as well as Blue G1 and G2. My rejuvination seemed to work on green as I had no green on the tube prior but now it's almost all green. The blue did not register at all on the 466 and red was very low. Do I need to connect the wires from the leftover blue and red somewhere for it to work? Can anyone help? Thanks
I have seen something similar happen when the adaptor was wired up in a reverse, or mirror image of how they should have been. Second check your wiring.
