BK2K backglass lock/cam
where would i find a lock/lever/cam for a black knight 2000 backglass?
Unless there is something special about this machine it should be pretty common to find at a place like Marco or Bay Area Amusements. I got one in back ill go look at later.
If its just normal then the lock and cam can probably be bought at home depot minus the little plate unless you want to drill and cut one out...:)
yeah lock is normal i believe(BK2K i just bought was totally gone so nothing to compare), but the cam(arm that actually rotates and pushes this loong rod to stop backglass from coming up/out) is bent into a perfect position for this game/backglass i guess. it has to be the correct one because it is a tight spaced area. i tried finding at both Marco, Bay Area, and Mad Amusements as well...no luck or just not searching for the right terminology!!
