peerless
Caveat emptor. Several Negative reviews
i have the right adapter. how do i use the rejuvinator on a sanyo ez20. cant seen to find the tube number in the chart.
thanks in advance!!
thanks in advance!!
thanks in advance!!
ok, i set it to 6.3v the other to 50v doesnt seem to move when i try to set the cutoff.
thanks again!!
thanks again!!
I believe that means you have to switch it from 50 to 250. Just ask asnatlas1000. Add some juice, it'll move.
Did you try the cutoff on all three guns?
I didn't attach it to the tube yet. I just was trying to get everything set first. Should I have it connected to the tube first to calibrate everything?
Snort .
