SOLD - PARTS BK 467 Tube Rejuvenator
Final price drop before it is delisted and put back into storage next Friday
Note that the harbor freight Apache case is a perfect replacement
I'm very surprised this is still available. These are always in high demand, especially this model.
I would be interested but it lacks cr23 and cr31
Ready made replacements are $50 each so I would have to spend at least $100 more to use it. Just sux 😢
There are folks here who make adapters, search around.
and HF has 30% off Apache cases 8/23/24-8/25/24
Making the adapters isn't hard at all. You can download the pin out map and make your own with a used TV neck board or a new socket from arcadepartsandrepair and a molex connector. There was also a guy who had a PCB layout you can send to have made. I have 3 different rejuvenators and none had the common adapters so I made my own. My biggest recommendation is hot glue all over the back of the socket so you can plug and unplug it a million times and not worry about pulling your heat shrink off wiring.
