ok i finaly said to hell with it and decided to work on my cab. (fixing the water damage.) got some pictures and need some help deciding on which way i should go about this..
http://s128.photobucket.com/albums/p172/punkshere2stay/battletoads arcade/
that's the link to al of the pictures i have in there are the pics of the water damage to the sides and bottom
an can you guys tell by the pics if my monitor has had a cap kit installed on it?? i know the pics suck its a old cheap cam.
the side aren't that big of a deal i see you guys using bondo to repair broken corners and such but since its water damage is it safe to sand back down smooth? or is there something else i am going to have to do?
now the bottom........ its got water damage from front to back and side to side.... the front two levers are broken out.... should i take the bottom out and replace it??? judging from what i see as to how its attached shouldn't be to big of a deal..
this is the first time i tipped this thing on its side... to truly look at it...
