Biggest tri-sync monitor?
bimm25i
Ohio
anyone know what the biggest tube available for a tri-sync crt is?
I have a 38" hole in a showcase cab I'd like to fill
i have a couple of showcase cabinets and they both had 33inch crt's in them.
thanks are they tri-sync? I have one right now thats a maximum force dedicated and it has a 39" (36" viewable) standard res monitor in it. but I want to upgrade to tri sync if I dont have to sacrifice monitor size.
The biggest tri sync that I know of is 33".
I use a 33" D9200 in my showcase. This is Tri sync. Keep in mind it will do either EGA/CGA through one plug, but if you are switching to games using VGA you have to actually physically move a plug for that. So in my cabinet I use only CGA/EGA games.
I believe that the Neotec NT500DX is also tri sync but I'm not sure if it comes in sizes bigger than 27".
The 33" D9200 can be kinda hard to find. 27" are everywhere.
Nec 37" presentation monitor.
265 pound of glass and plastic.
You can run an arcade game thorough the regular db15 connector.
It does have vga.connector also composite svga bnc. The max resolution is 1024 by 768.
You need a remote to switch the inputs. I think.
In the US it's always the viewable screen size that counts or else you should call the 19" 20", the 25" 26", the 27" 29" etc. It's a matter of consistency.
While stuffing a Monitor in a pre-existing cab the physical size is more important than the view able size. It's a matter of does it fit or not.
