hey all thanks to the pictures i got i think i have the wiring on the big buck hunt safari deluxe figured out, how ever one new problem has shown up and another is still ongoing
the first problem is the game wont boot and it wont boot the restore dvds on hand, the hdd is a 2005 80gig sata drive, could i take a 256gig ssd and create an 80gig partition and use that as a replacement/upgrade?
the other problem was there when i started working on it, when turning it on it trips a breaker, it is set for 115v and is on a 30 amp breaker
today i noticed the issue seems to be the monitor, if i disconnect power at the monitor side everything starts up normally, the strange thing is, the monitor seems to work fine without issues
i did notice some caps going bad on the inverter board, not sure if that would cause it, is there any place sells cap kits for these monitors? or can a normal 42 inch tv be used as a replacement?
any help or advice on this would be great.
