Have a Safari that occasionally will boot up with a CPU Fan failure and requires a keyboard prompt to continue. Already changed the fan and still get the error (fan is spinning). If I use the keyboard to get past the error, the game loads and runs fine and I can power it down and back up and it'll be fine. Is there anything else that would cause this error?
Also, is there any way to turn off the registration prompt with these? I didn't see anything in the test menus about doing that.
With the Pro, you'd have to be a real pro to be able to remove the monitor pcb! In my 20+ years, I can't recall any cabinet where you physically can't remove the monitor pcb w/o having to remove the whole monitor (see photo).
