Big Buck Hunter board wont load keeps resetting.
JBuck8
rocklin, California
Like the title says I have this big buck hunter pcb and i plug it into my golden tee 2004 cab and the board fires up and says the bootrom version and says detecting modem, then it says loading game, and then it resets and will do this as long as i let it. Does anyone know what my problem might be? Thanks for any help.
most likely the hard drive is bad.
However check your voltage, I've seen these board flake out if the volts are off.
big buck
I bought this board for the video card and thought it was a golden tee board. The Golden tee board i have works fine and in the test menu it says the voltages are fine. I dont know what year the Big Buck hunter is. I bought a Big Buck Hnter 2 hd and the board still resets. I plugged my golden tee 04 in with the big buck hunter 2 hd to see what happened but i didnt do the same thing it loaded and said it was a big buck hunter 2 hd and the a red screen came up saying incompatible hd. Wouldnt the big buck hunter board do the same if the problem was just a wrong or bad hd?
Thanks again
The board may be seeing the BBH2 HD and noting the incompatibility, but it may not be able to access the other HD to determine what it is. The fact it says it's loading files indicates to me it is trying to access the HD and can't, so it resets and tries again.
hd
I have the Big Buck Hunter 1 shooters challenge hd on the way will let you know as soon as i get it. The seurity chip on the pcb says 2002 and bbh1 shooters challenge and bbh2 sportsmans paradise came out in 2003 so i thought i might have the wrong hd and ordered it a couple days ago.
thanks
Jeff
Got the hd
Ok so i had a couple hurdles but i got the right hd. Its a bbh shooters challenge. So i plug it in and turn it on and i see it go through its loading steps but the when the game starts i hear the sound but its a black screen. Then every now and then it will reset. It reloads and i see it recognize the hd and do the system checks but when the game starsts its still black. Do I need to change the res onmy monitor or should i try a diff video card that i know works?
thanks
Jeff
Maybe this sounds dumb, but make sure your power supply is putting out the correct voltages.
