FirebirdTPG
Anyone have experience with programming Bi-Polar Roms? Even better have experience doing it with an Andromeda Programmer?
Thanks!!
FB
Thanks!!
FB
Do you have this adapter?
BIPOLAR PROM ADAPTER
Part #ABIP - $189.00
This adapter supports all 82SXXX and 74SXXX bipolar proms (16 through 24 pin). Bipolar proms are special high speed memory devices which program by blowing internal microscopic fuses. The circuitry on the adapter generates the high power signals necessary to sucessfully blow the desired fuses in the device's memory array.
I am certain they are blank. I am able to verify that with the programmer.Are you certain your 82s126 are good and blank? Can you successfully read a pre-programmed 82s126?
An alternative is to use a 82s126 to 27512 adapter and a fast 27512 EEPROM like the Winbond 27c512. Take a look at my Choplifter to Wonderboy conversion
Choplifter to Wonderboy Monsterland conversion
For a long time, I had a desire to play the properly translated Wonderboy in Monsterland (Wii virtual console), as I remember playing it BITD. I have an English bootleg but it is so poorly translated it is not fun to play. The ROMs for the Wii virtual console version exist so I wanted to try...forums.arcade-museum.com
p
What brand of proms do you have ?
There are "first generation" proms which are harder to program.
NEW - eprom programmer that will program proms / gal's
I used a Superpro back in undergrad -- I wouldn't exactly call that modern :) For once I agree with mark! I do not enjoy the Superpro we have at work, and that's something we only bought 3 years ago.forums.arcade-museum.com
You could also have a batch of bad proms.
These chips are over 40 years old, and some do go bad.
Other than that, some things you can look for
1- Have you selected the "exact" prom type on your programmer ?
2- Do you know that your programmer is actually "programming"
Does is show the programming progress until 100% completion ?
(ie. the chips are no longer blank after you program them )
3- If the chips are incorrectly programmed, do they always contain the same "bad" data ?
(ie. every bad chip has the same checksum value or are they different ?)
4- Have you tried programming completely different proms to see if those work ?
Try that, and report back.
Thanks,
Steph
