www.arcadepartsandrepair.com
I agree, this isn't a connector issue, it's a workmanship issue. Those are supposed to be heat shrunk around to reduce stress.That is what is generally out there. You might want to adjust your methods. Downsize your wire, use less solder and more heat shrink.
Exactly what I was thinking about but couldn't find. Where did you see that?If you want a little durability with the blue edge connectors, you can try covering it with something like this
p
