Betson MTG2901 monitor clicking?
FlashbaxArcade
Burleson, Texas
i have a monitor that i'm not familiar with...it's a 19" Betson MTG2901. it's brand new i believe and all it does is click every couple seconds. i used an ISO but not sure if it needs it!
ok pcb has MTG 2901 and also has 1901 and is the Tovis.
any help?
read about ticking sounds from other monitors so i decided to pull chassis and ck for cold joints but nothing! went ahead and reflowed all connector header pins and even flyback. also read about having a bad pot....my H Size white plastic adj knob on pot is gone/broken off!
could this do the power up/tick tick tick problem?
Did you replace the flyback? I know they'll click when they go bad sometimes. Could also be a cap, can you see any that look bad?
nothing replaced yet...been waiting for someone to chime in with experience with these models. nothing looks physically bad...it looks brand new!
maybe someone knows the caps that i could replace cause i'm sure that these probably do not have "capkits" yet.
