I have a bestech chassis 29ce-m and I attached a JAMMA harness with a PCB to the monitor using a standard RGB connector. The monitor does have signal, but it either isn't syncing because I don't know where the sync connection would plug in on this unit or where the adjustment is... I need some help. Anyone got a schematic of the connections or a picture with there monitor hooked up? The chassis just doesn't have clear labels so it is difficult to guess.
thanks!
thanks!
