just guessing here, but see that C-clip on the shaft, toward the top, just above the white actuator? Get pliers and pull that off. If the shaft doesn't pull through after that, looks like there's a lock-screw on the side. Loosen that and see if the shaft releases up through the body. Doesn't the body mount under the CP?
