Hi all,
I'm planning to re-do the wiring harness edge connector on my Centipede, but when I pulled it off I noticed that the ground connection is partially burnt. The previous owner had solved this by placing a small wire inside the connector that bridged across to the metallic edge, but I'd like to solve that kludge if possible.
Suggestions? I don't have any copper trace foil, and don't know if that's necessarily the best solution for such a small area.
Thanks in advance for your help... I've never done anything like this before and want to make sure I do the right thing!
