I've used that spray adhesive stuff before and it works pretty good for light-use applications.Ok, will check it out. Anyone every use the 3M 80 spray adhesive for this sort of thing as well?
Just trying to get all opinions on what people have used with success.
I am attaching rubber matting to an APB wood seat base.I've used that spray adhesive stuff before and it works pretty good for light-use applications.
So I think it might depend on your needs. What is your situation? What are you trying to do?
This is a nice table that looks at 3M spray adhesives
I have used 90 for a vinyl mat on wood (OutRun and Super Hang oN), it worked great but I guess the 3M 98 would be the spray of choice...
p
Agreed, I think I went with the spray because the game was in the basement and I didn't want to smell the VOCs for days afterwards…The -90 is stronger than the -77. And it might hold up in a home use environment. But I wouldn't recommend it.
Based on that chart you're right....the -98 is the correct choice.
I would still go with the DAP Weldwood. You'll need a chisel to remove that even 30 years later.
