txplayer05
i have a centipede upright with an 19" electrohome monitor that probably needs a cap kit and a crt 19" also. just wondering wich one should i use if i want to build a jamma machine. i am leaning towards using the crt but i have a couple of questions like how to mount it in the upright case. i cant find any information on how to mount a computer monitor in the upright cabinet. also how do you turn it on once its in the cabinet behind the glass since dont you have to turn it on by pushing the power button in the front of the monitor. now to the other side the electrohome monitor just needs a cap kit and how would i connect it to the jamma wire harness. i hope someone has a picture of how and where to connect it because i have no clue. ok if i somehow figure it out how would you connect the power cord to the new power supply that the jamma board uses. i dont know if its even compatible with the old electrohome monitor. would i have to keep the existing old power supply for the old monitor and install a new power supply for the jamma board. i really hope someone can help me out here. also i read something about installing a test switch but they didnt say which or what kind of switch to install. well i ordered my jamma kit so it will be here this week and hopefully by then someone will read this and help me out with these questions. thanks...also i need a cap kit for my electrohome 19" 38-GO794-10 COL GAM MT monitor if anyone knows where i could get one once again thanks...
