ChaosJohn
The point I'm trying to make here is: if you have an OCTAGONAL restrictor, then your movements are restricted to those 8-ways, eliminating the problem of landing in that "dead zone" where you think you're going UDLR, but you're really in a diagonal. This is the "missing the turn" problem you get with using just any ol' 8-way stick. The octagonal restrictor allows you to play the pacs AND the 1943s equally well with no switching because it elminates that "dead zone."
I see your point, but I'm not completely convinced.
The problem isn't just a dead zone, but quickly getting from one side to another... Let's say left to top. The problem occurs because when you're moving from left to top with a 4 way, there's a crossover point where you just switch over and you're clicking top and not clicking left. With an 8-way, there's that diagonal zone where you're clicking both left and top.
If you've played a four way game (let's say Ms. Pac-Man) a lot, then you're used to anticipating wanting to turn at the next corner and you already have the joystick clicked into the turn. Unfortunately, if it's an 8 way, you might still be double-clicked, and since left was clicked first, it will ignore the top click.
I guess with practice, you could learn to be meticulous about centering between each click or focusing on where you are with the octo-restrictor, but either way I think it would take some re-learning to get used to playing a 4-way game with an 8-way joystick.
The bottom-switchable joystick is fine, but let's say you're at a party and you're playing Ms Pac and then someone says, HEY! LET'S PLAY GYRUSS!!! Do you really want to open up the control panel and remove a restrictor plate and replace it?
There are some top-switching 4/8 way joysticks, but I think I'm going to go with the simplest solution here. The control panel was actually set up for two players, so there are 2 8-way joysticks with 3 buttons each... I'll just switch one of them to a 4-way joystick and wire both sets of controls to player 1. That way you can play 4-way games with a 4-way stick and 8-way games with an 8-way stick without any futzing around or switching. And it'll also save me stripping and patching up and re-covering the control panel to a single set of controls.
