TerryMasters
Best JAMMA switcher - only needs to switch between two boards
Hey everyone. I have two Mortal Kombat game boards that I want to switch between in one dedicated MK3 cabinet. One game board is an UMK3, the other is a MK4. Now wiring up the extra run buttons and whatnot should be cake, I just need to find another set of the extra harnesses. What I really need help with, is finding something to plug into the JAMMA connectors on the game boards that will let me flick a switch to choose the game.
This should be simple enough, although the MK series is one that requires the -5V. I saw that MameMan uses a 6-in-1 switcher on his setup, but since I'm only switching between the two I figured maybe there was something simpler I could use. I'm really trying to avoid having to wire up diodes and such.
What do you guys recommend?
