docfrankie
curret flow in this application is a non factor
It was cleaned as well as I could clean it. I used an eraser and alcohol on the pins and an alcohol soaked cotton rag over a credit card pushed into the edge connector. I know that probably didn't get the terminals in the edge connector fully clean, but I don't know of any other ways to clean them that are non-destructive. The terminals may have lost tension too; given that the whole thing was 20 years old.If your adapter was dropping .2V, then it was dirty and needed to be cleaned.
Your board takes approximately the same amount of current regardless of what voltage you give it... putting out 5V instead of 5.2V isn't going to make any difference in the lifetime of your power supply.
I just realized i typed Adapter. oops! I meant Harness!
dude your splitting hairs with an electron microscope
let the OCD go.
most IC circuts, resitors , caps ect.. all have tolereances +/- 10%
5VDC vs 5.1VDC no biggie
That doesn't render the impedance of the wiring irrelevant.
Yadda yadda yadda... if you agree that solder joints have ANY impedance, than 3 solder joints have higher impedance than 2 solder joints. EOD.Solder joints have a higher impedance than wiring or traces, to varying degrees depending on the solder alloy and mass and length of the fillet, and the material the wires and traces are made of and their mass and length...
I'm saying it doesn't make one damn bit of difference, and that 'current flow' is a red herring, and that Bob's just trying to convince you to buy what he sells.But regardless of all of that; is it your claim that it is impossible for one to make a fingerboard/wire type adaptor with better current flow than a JAMMAboards PCB-type adaptor?
wear and tear on itself? Shouldn't more voltage from the power supply (regardless of whether the board uses it or not) generate more heat in the power supply? Plus, if the board isn't using the extra voltage, then it has to be dissipated as heat somewhere at the board, which I don't see as a good thing either.
If the contact impedance is 1 ohm, and the trace impedance is .01 ohm, and the wire impedance is .02 ohm... Yes, the wiring impedance is irrelevant.
And Dynamo built them before you did, and probably someone built them before Dynamo did. That wasn't the point however. I specifically mentioned JAMMABoards to distinguish them from a PCB-type adapter that may be higher quality.And you might as well call that a Spaeth PCB-type adapter, since I made them long before AS or JammaBoards![]()
EVERYTHING GETS DISSIPATED AS HEAT.
[mod delete]
OMG! .1V difference at 2A! That's .2W! That'll heat 1g of water 1.43 degrees C! HOW COULD MY PCB POSSIBLY WITHSTAND SUCH HEAT!
[starting threads with personal insults is getting quite old.], but for those who might actually be trying to learn something in this thread;or that using 20 AWG wire for power and ground vs. using 18 AWG doesn't make a bit of difference. Throw good practice out the window because according to Mark, "it doesn't make a bit of difference"?
And some of his statements suggest that he does believe that it is impossible.
Yes you can always get a lower total impedance with a wired adapter by 'adding more wires'...
Indeed, but that has nothing to do with the argument.well guess what I can get a lower impedance on a pcb-based adapter by adding more wires too.
What you're talking about here has to do with safety rather than the argument at hand. Just because Y number of 20 AWG wires can safely carry X amps without catching on fire doesn't mean that you won't get reduced impedance with heavier wires....and as for 18ga vs 20ga... no that doesn't make a damn bit of difference either. 18 ga wire is ~6.4 ohms per 1000 ft... 20 ga wire is ~10.2 ohms.
20ga wire has a (conservative) ampacity of ~3.5-4A... considering power wiring is always done in parallel (with 2-4 wires), that gives you 8-16A on your +5, which is FAR more than any game I've ever seen uses. Most harnesses are built with lower gauge wire on the power, mainly to differentiate it from the other wiring, which never really goes much above 20ga for mechanical strength.
I have no use for adaptors. I've only ever needed one once, and that was for when I first got my Punch-Out machine which had been converted to JAMMA. I built an adaptor for it until I was able to find an original Punch-Out harness....but hey.. if you want to waste your money and spend more on Bob's ugly adapters because you think .01 ohms is going to make a difference in your game, that's your prerogative.
The answer is: Yellow.
Common sense will tell you that the answer is: Pumpkin.
...only until the end of October.
There's nothing left to argue. See above.
