original Xbox + COIN OPS IGNITE MAME + http://cgi.ebay.com/Xbox-console-ti...241?pt=LH_DefaultDomain_0&hash=item3a623ff6a1
Can run CPS3, CPS2, and any classics. Affordable and works very well.
I'm assuming you would haft to run Linux and configure a front end? If so a xx in 1 pcb would be better/ easier for a novice
is the monitor horz or vert?
The 48 in 1 is no longer available, it was replaced with the 60 in 1. I was going to suggest this for its great selection of classics and ease of setup. I believe forum member Nixs sells these for a little over $100. Note: I actually have an older 48 in 1 I'm running in a Scramble cab with a Jamma adapter. Gets the most love at virtually every gathering I have.I am thinking of going with one of these 40 n 1 or the 60 n 1
Whats yalls input? http://www.arcademvs.com/PC_BOARD.htm
