Question #1: where do I hook up the switcher cable? Anyone have pics?
Question #2: I installed my ZZPU, only for it to not fire up and blow fuses. I replaced the fuses, put the old board back in, and thankfully it worked fine. Now I'm a bit paranoid about trying to put the ZZPU back in. Obviously, I did something wrong. I noticed that the original board has a clipped pin and the corresponding hole on the molex connector is plugged with an insulator. That same pin on the ZZPU is not clipped. I assumed that it needed this pin on the ZZPU, so I removed that plug when I installed the ZZPU.
So I think my question is whether or not that pin should be snipped? Do I need it? If I don't, is that why I blew fuses? If I do need it, what do you think I did wrong? I didn't miss any pins, and the ribbon connector was hooked up correctly.
Help a humanoid out.
